Libraries with Duplicate Objects
Bill
I've added a BimServer Library (our office library) to a project, and it's telling me that there are duplicate objects... actually, it's telling me that the Office Library has duplicate objects with itself. There are no other libraries loaded with these objects, and it's definitely referencing the same library each time...
Any thoughts as to what is going on, and how can I get it to believe that there are not duplicates?
undefined
Bill Szustak RA
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
13 REPLIES 13
NCornia
Graphisoft Alumni
Well now I am embarrassed. It seems your wish is coming true very fast! The feature will be in ARCHICAD 20:
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
R Muller
Wow! You work fast!
R Muller
AC 28 USA (20+ years on ArchiCAD)
MBP 64GB Apple M1 Max OS 15 Sequoia
Hi, good folks.
I am having the same problem that have been reported here (AC 20 5025, macOS Sierra).
With the BIMObjects add-on, I get hundreds of duplicates (90% of which are not placeable) despite all files that are branded "duplicates" having the same file path. Tried deleting and re-downloading libraries, changing destination for download folder, etc. with no success.
Any suggestions?
Is it possible that you have downloaded and placed multiple BIMObject GDL Objects into your ARCHICAD Project file and they are using the same macros? Each GDL Object probably downloads its own macros and includes them in the Libraries, but in case of two such objects those macros may be the same and this may cause a duplicate object warning. You can check this in your Library Manager Dialog.
