2007-08-09 07:42 PM
2007-08-10 04:42 AM
siteline wrote:There's the problem right there.
except AC 9 is not installed on the other computer.
2007-08-10 04:55 PM
2007-08-10 05:57 PM
siteline wrote:Well I certainly wouldn't think you'll need to change hundreds of parts!
Thanks for the reply, Link.
I thought the AC9 might be the problem. I'll try it from the server. This is the only project left from our switch to 10 a few years back and I haven't had the heart to go in and change the hundreds of 9 items to 10. I just might have to if that doesn't work.
Those other objects you see are the job specific library items which are stored on the server with the project. That's the way they always load. They're kept in a folder which is with the pln or plp. Is there some other method which would be better/faster?
Thanks
