Library Part Maker not transferring parts to other projects
toman311
I have made a window and when I check it, ArchiCAD gives me the green check mark. When I try and use it in another project file, the window comes in as an empty opening. When I place it in the Part Maker template file in a wall, it works. I tried to see if I could import the example window and the same problem occurs. So, does anyone know why I cannot use my Part Maker windows in other project files besides the Part Maker template that it was made in?
>ArchiCAD 23, 7000 USA FULL
>iMac, 27-inch, 2020, Processor: 3.8 GHz 8-Core Intel Core i7, Memory: 64 GB 2667 MHz DDR4, Graphics: AMD Radeon Pro 5500 XT 8 GB
4 REPLIES 4
Dave Seabury
Toman
If I recall correctly, LPM (or at least the some part of it) has to be
loaded in the project for LPM objects to work correctly. I think it was
in the documentation for LPM.
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
toman311
I didn't see anything in the LPM for ArchiCAD 20 User Guide which explained how to install it at the beginning. I followed its steps on installing. I am not sure why it isn't working?
David Maudlin
toman311:
In the Applications/Graphisoft/ArchiCAD 20/Library Part Maker 20/ there is the Library Part Maker 20.lcf file. Maybe this needs to be one of the loaded libraries in the project file.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
toman311
That's it David! I don't know why I didn't try that before. I thought I looked everywhere. Anyways, once I install that in the Library Manager, the empty opening turned to the window that I imported. I just tried this with the stock window example in the template, so I guess I still got some experimentation to do with my own windows and such. I guess that just would come down to drawing it correctly in the template.
Thanks guys!
