Aurasphere
ATTRIBUTE TRANSFER: AC Library issues
I am testing out template stuff for client atm
What I notice is that the floor plan element display is quite granular for eg v26 windows
Great
But how do you take eg just the floor plan uncut/cut pens etc and apply them to other windows without affecting geometries etc (despite using the transfer settings template}
Could anyone show how they have successfully done this as the actual transfer settings seems quite ambiguous
Just to clarify, this should inject equivalent attributes without changing the window type etc
It works on identical window objects when I trim down the inject filter but it seems to always apply a change of object which I dont want...simply need the same attributes without applying "override" attribs in generic dialog
Cheers
Mark Wesse
AC26 | Win10 | Since v6.5r
Architerion - Architectural Systems Developer
Aurasphere - Acoustics
Building Biology - Human Compatible Architecture
"--- Every time...do it better ---"
0 Replies 0
