2024-10-06
03:53 PM
- last edited on
2024-10-06
06:34 PM
by
Hello, does anyone know how to make the object appear in the library? I have loaded the library more than once, but the carpentry object does not appear in the Objects tool. Thank you!
Operating system used: Windows 25
2024-10-07 03:48 AM
Can you browse through the Library Manager to the object? Loading the correct version of the library?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2024-10-07 09:07 AM
What is the 'carpentry object'?
Is it just an object or does it have a special sub-type which means it may not be usable as an ordinary object?
It may need to be used with an add-on?
Or it is not made for your Archicad version.
If it is a newer object (say version 27), you will not be able to see in on older version (like 26).
You operating system says "Windows 25" which is interesting.
Do you mean Archicad 25?
If so the object needs to be written for version 25 or older.
You won't be able to use it if it was written for version 26, 27 or 28.
