Library archicad 27 to 28
Guillermo1
Hello, I created a file in Ac27, later I opened it in Ac28 but it doesn't recognize the Ac28 library, for example, the flexible pipe doesn't work, which I think is a library management issue.
JohnB
MEP library objects área not longer a library parte inferior AC 28.
MEP TOOL in AC28 is different than AC27 or earlier versions.
Have you loaded both the Archicad Library 28 and also the MEP Library 28? If you are opening a file from 27 to 28 do not load the .libpack Libraries.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
hi, i loaded both archicad library 28 and mep library 28 but dont recognize the flexible pipe tool, when i open the basic library it show the 27 folder only
