‎2024-12-14
08:12 PM
‎2025-01-02
03:28 PM
Molinda Prey
Hello, I created a file in Ac27, later I opened it in Ac28 but it doesn't recognize the Ac28 library, for example, the flexible pipe doesn't work, which I think is a library management issue.
‎2024-12-14 09:31 PM
MEP library objects área not longer a library parte inferior AC 28.
MEP TOOL in AC28 is different than AC27 or earlier versions.
‎2024-12-14 11:15 PM
Have you loaded both the Archicad Library 28 and also the MEP Library 28? If you are opening a file from 27 to 28 do not load the .libpack Libraries.
‎2024-12-16 12:21 PM
hi, i loaded both archicad library 28 and mep library 28 but dont recognize the flexible pipe tool, when i open the basic library it show the 27 folder only
