Dwight
Library loading of giganti Objects Problem
On my MacPro, there's a problem loading certain new library elements. They are a series of winged nymphs that are around 20 Mb each converted via 3Ds from Poser.
They operate correctly in the actual model, but despite being installed directly into my Custom Archicad Library Folder [separate from the actual Archicad Library 11] , they show up in the library loading dialog as a list of "Other Objects," their folder being colored blue.
It is as if they cannot be loaded into the library like other elements might.
Any insight?
Dwight Atkinson
When you do the conversion, the created objects show up under the blue 'other' folder even if they are saved to a loaded folder, as I recall. (Recollection is a dangerous thing though.) In Lib Mgr, just delete the entries under other and reload?
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
