2018-02-20 12:05 PM
2018-02-21 01:48 AM
2018-08-09 05:32 PM
JGoode wrote:Hi,
If anyone has experienced this previously, is it fixable and if so, how did you fix it?
Thanks!
Library part was not converted properly (Tárgy - 002)
2018-08-10 03:03 AM
furtonb wrote:As soon as I checked the 3D script i cot this error.
No errors in any of the scripts, 3D view and 2D views are showing up properly. I have the 2D view in the plan, but no 3D.
2018-08-12 06:23 PM
Barry wrote:Thanks, that one didn't catch my attention – I'm not sure, it's possible that I checked the 2D script twice, and I skipped the 3D script.
Library part was not converted properly (FU - 002) Not enough parameters at line 1 in the 3D script of file kosáríves donga 21_fb.gsm.
2018-08-13 03:18 AM
This is different though:Library part was not converted properly (FU - 002)
2018-08-13 06:45 AM
That is the same error I was showing in the image I attached before.
You just have to make sure you are fixing the correct object that is being used, the one in the linked library or the one in the embedded library.
