Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
Library parts
Hello! I have a problem... Archicad 8 crashes when I add a new library I've created from downloaded objects from internet... but only when the original lib is loaded. I really don't know what to do!! I have in that tlibrary more than 3000 objects! Help!!!
5 REPLIES 5
You can narrow it down to the offending part fairly quickly with a binary search:
1. Load half the library.
2a. If it crashes, load half of what you loaded in step 1.
2b. If not, load half of what you didn't load in step 1.
3a & 3b. Repeat, cutting by half each time.
This will resolve to a single item in 12 steps.
Thank you!!!!
I'll try it right now!!!!
Pure maths!!!
You saved my life!
Thank you
Djordje
Ace
Do you really need all the 3000 objects loaded at all times?
Why ArchiCAD 8, the worst ever? 8.1 was free ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
you can never know when you'll need a tinny tea spoon... !!!
I, sorry, you guys, fixed my problem!!
Thank you
