Linked Library is not being found
Hi there,
I added a library (consisting of just one window) to my project. (SEE fig 1)
But When I am trying to apply it, the library is not showing in the linked library. (SEE fig 2)
I attached both the library and pln file. Can you please help me to solve the issue?
https://drive.google.com/drive/folders/1UOJZxnNAtlKRPfYCXl_b4wsbuCfEqfAr?usp=sharing
If it is just one object you will probably find it in the embedded library.
If you load a folder it will be a linked library.
If you load a single object it will be in the embedded library.
Lingwisyer
Guru
The object is defined as a window right? Not a sash or something else? When you reopen the library dialogue, is the added folder still there?
Ling.
EDIT: Duplicate library part. Loads fine for me.
I just downloaded your 'Library - Schematic' folder and using the 'ADD' button in the library manager it did indeed add the folder as a linked library with just the one window object in it.
What is the one warning message in your library manager.
That may offer some clues.
Actually I just checked and I have the same warning.
It seems you have managed to copy a window from the Archicad library rather than saving as a new window.
Simply copying and renaming does not change the internal GUID, so Archicad considers them the same object.
Sometimes these duplicate objects will only show one or the other.
I am not sure why I am seeing both and you are not.
But your window seems no different than the 'Vertical multi-sash window 23' - so just use that instead?
