Listing Parameters in a Schedule
Hi there,
I need to list the variable N of a certain Object in a Schedule. (bread-n-butter)
the variable N is actually a counter in a loop ( for i=1 to ..... N=N+1...)
By the end of the loop N stores the value for the number of loops.
Here is the problem:
If I create the Variable N in the Parameter List (main window of GDL) it will remain always 0 and will never show the real value of N, therefore useless for my Schedule.
I've tried moving the value to another parameter ( counter=N), doesn't work.
I can see the value by means of ( text2 0,0,N) but I really need to schedule several objects and add up the values.
What do I need for N to show the real value in the parameter list? therefore be able to schedule it?
thanks in advance!
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
2 Replies 2
"parameters n=n" in the end of parameter script does not work?
Where the calculations are done in the object?
Best Regards,
Piotr
Yep, I tried that, doesn't work. by the way I also thought that was the solution.
I'm doing the calculation (the counting) in the 2D Script
The weird thing: it works with GLOBAL variables, like SYMB_POS_X and so on. but not with LOCAL variables.
thanks for the reply Piotr
Nando Mogollon
