Location of subtype gdl files
Hello everyone,
i'd like to take a look in the gdl files that define the object subtypes to understand their built in functionalities.
The subtype hierachy shows the path as:
/ARCHICAD 21/Support/ARCHICADRessources.framework/rfs/filename.gsm
The only problem is that there is no folder called "rfs" in the .framework file. Can anyone explain where i could find these files and maybe how ArchiCAD is working with .framework files?
Thanks in advance!
2 Replies 2
Lingwisyer
Guru
You can open them by going through the calls in an object. Highlight the name after the call, then select "Open object". Do not know of a way to open them directly...
Ling.
Or use "open by subtype" command (located in GDL editing toolbox)
Piotr
