Lost Library Part:How could I recover my HACHURE in library?
Hello everbody!
I'm not good at ArchiCAD and here I have a litte question about my lost library part: Normally in Library 10 there's a lot of Hachure, line type and zone stampes ( vector objets ) for choose... I don't know how but I lost all these vector objets, so I'd like to know where could I download them ( I've already tried to update my library but it doesn't work ....
THANKS!
3 Replies 3
TomWaltz
Those are not part of the library. They are set in each individual Archicad PLN file, so there is no library to add. It's part of the reason a solid template with all the fills, layers, line types, etc. is so important.
Tom Waltz
If the line types, fill types, etc. that you are missing are part of the default set, you can recover these by a "New & Reset" (File menu with alt/option key). The new untitled file will have all the default attributes. Save this as a default template and use Attribute Manager to import them into your existing file.
Ah!! It's for this raison that I couldn't find them in my library: they're not libraty elements but template elements... Thank you so much Matthew and TomWaltz
