yuza
Archicad25 Library Section NCS Marker missing!!!
Hi
I use Archicad25 and I recently realized that my NCS Marker 22 is missing. I can't seem to find it in my system. How do I recover this library?? pls help
Thanks
Lingwisyer
Guru
Are you running the US version, not the INT one accidentally? Though it you were using NCS Marker 22, did you export it to some external folder? If so, make sure you are loading that folder into your libraries.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
You probably need to load the migration libraries.
The 22 marker may not have been updated all the way to 25.
