Making a specific window
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-02-20
12:32 PM
‎2023-05-24
12:43 PM
Rubia Torres
I cant seem to find a window that has two side-hung windows (one on each side) and a whole fixed window in the middle.
Check Attachment for picture
Please Help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 01:54 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 02:00 PM
But how do you put in a transom (or split) that devides the two opening windows. but not through the middel one?
If you know what i mean.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 02:36 PM
You ask how to remove the transom in the middle of the window?
Or You have a view ask device of "opening lines"?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 02:54 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 03:08 PM
dD3 wrote:You can create a custom window panel if you cannot find what you need in AC Library.
Simply make your window panel from slabs; then go to File > Libraries and Objects > Save Custom Component. Choose "Custom Window Panel".
After this, choose a window, go to its settings > Sash - Individual Options, choose "Custom Panel" and the newly created panel should be available there (in "Custom Panel Name" field).
For more info, you can do a search for "custom components" in AC Help.
Cheers.
Adrian Tudoreanu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 03:12 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 03:28 PM
dD3 wrote:No sample on the basis of which it can be done. Even if you use "Custom Component". You should make its own window.
Like this..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 03:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-20 04:48 PM
dD3 wrote:In this case you can create a custom window. Make it from slabs and save the 3D model as a window (see attached image).
Then how can i do this?
Cheers.
Adrian Tudoreanu
