‎2008-02-20
12:32 PM
‎2023-05-24
12:43 PM
Rubia Torres
‎2008-02-20 01:54 PM
‎2008-02-20 02:00 PM
‎2008-02-20 02:36 PM
‎2008-02-20 02:54 PM
‎2008-02-20 03:08 PM
dD3 wrote:You can create a custom window panel if you cannot find what you need in AC Library.
But how do you put in a transom (or split) that devides the two opening windows. but not through the middel one?
‎2008-02-20 03:12 PM
‎2008-02-20 03:28 PM
dD3 wrote:No sample on the basis of which it can be done. Even if you use "Custom Component". You should make its own window.
Like this..
‎2008-02-20 03:31 PM
‎2008-02-20 04:48 PM
dD3 wrote:In this case you can create a custom window. Make it from slabs and save the 3D model as a window (see attached image).
Then how can i do this?
