We value your input!
Making a trapezoid window that slopes down?
Hi all,
I'm trying to make a trapezoid window that slopes down (see pic), as it is in a wall that is on a downward angle (see pic).
Any ideas?
Thanks
Lockers
vistasp
There should be a trapezoid window in the standard library. It's under Special Windows (in the INT version at least).
Alternatively, try the Free Form Window in the Depository.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Thanks vistasp, next dumb question tho! Once i have downloaded those files from the Depository, how do i get them into ArchiCAD??!
vistasp
AC needs to know where to find the objects so you have to make sure they're loaded in the library.
Basically, copy the gdl objects to a folder (or a folder tree once you have enough objects) and load those folders using:
File > Libraries & Objects > Library Manager
= v i s t a s p =
bT Square Peg
