2026-04-17 05:41 PM
I am trying to export the Mapping Values Table Json file, but the file comes out empty. Any ideas why that is?
Thank you,
Operating system used: Mac Apple Silicon 26.4 Tahoe
Solved! Go to Solution.
2026-04-24 04:48 PM
Hi!
As far my understanding goes right now in this topic, there's no mapping value table in any Archicad file by default. You'll have to dwonload it from here:
https://www.graphisoft.com/en-us/downloads/?section=mapping-value-table&localization=INT
After that you can customize it and import it to your project.
The exported file from Archicad only comes out with data in it, if you imported a mapping value table before.
2026-04-26 06:30 AM - edited 2026-04-26 06:31 AM
The mapping value table will already be loaded in the Graphisoft 28/29 templates.
If you have your own template that originates before 28, then it won't have a mapping table until you load one, which was linked to in an earlier post here.
2026-04-24 04:48 PM
Hi!
2026-04-25 09:06 AM
Thank you! That was the info that was missing (or I missed it) from a how-to video that was linked in one of the GS posts about editing the mapping value table.
2026-04-26 12:03 AM
I was able to download the mapping value table from the Archicad 29 template.
