Florin Luca
Mapping Values Json File
I am trying to export the Mapping Values Table Json file, but the file comes out empty. Any ideas why that is?
Thank you,
Operating system used: Mac Apple Silicon 26.4 Tahoe
AC25-29 Solo US (latest build) – macOS Tahoe 26.4 – iMac Intel i7 | MacBookPro M5
2 Solutions
dyer
Hi!
As far my understanding goes right now in this topic, there's no mapping value table in any Archicad file by default. You'll have to dwonload it from here:
https://www.graphisoft.com/en-us/downloads/?section=mapping-value-table&localization=INT
After that you can customize it and import it to your project.
The exported file from Archicad only comes out with data in it, if you imported a mapping value table before.
Go to post
The mapping value table will already be loaded in the Graphisoft 28/29 templates.
If you have your own template that originates before 28, then it won't have a mapping table until you load one, which was linked to in an earlier post here.
Go to post
4 Replies 4
dyer
Hi!
Florin Luca
Thank you! That was the info that was missing (or I missed it) from a how-to video that was linked in one of the GS posts about editing the mapping value table.
SeaGeoff
Ace
I was able to download the mapping value table from the Archicad 29 template.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
