Deffect
Marker for Cutting
For my work I need to have a specific marker (cutting), but the problem is that It is not available in Archicad 27 library. Where I can get/download it?
1 Reply 1
Guru
By the sounds of it, you have used said marker in a previous version of AC. You should probably provide the object name rather than some generic descriptors and image. You could always load your old libraries and extract if from there, or file if it was an embedded object. Also ensure that you are running the same localisation of AC as some libraries my vary.
Ling.
