Marquee cuts
Tom Krowka
Hey.....we used to be able to take an object, cut it with the marqueee, then save that piece throught the 3D windows an another new object. That seems to have been lost? Or has it.
Thanks Tom
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
6 REPLIES 6
Hm, this looks like a bug to me.
I managed to save it, the 2D of the saved object reflected the cut, but its 3D did not. I did it with the latest 4008 build of AC17.
I will report this to GS.
Tom Krowka
Yeah, and I need it fixed by this afternoon so I can use it.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
David Maudlin
Works here if the cut is made with SEO rather than Marquee, for a quick work around.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Tom Krowka
Thanks. Two heads are better than one.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
Marton Kiss
I just wanted to confirm that Laszlo has reached us with this particular issue. Back with the previous versions there was the Save 3D Window as... command that could result the cut object. Starting from ArchiCAD 17 we have now the Save selection As... option, which helps in many cases, but not in this one.
We are checking at the moment how we could implement the old way with the new set of available commands. Until then, please use the SEO trick.
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Tom Krowka
Good to see GS is following Forum comments.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
