Marvin Window Library and custom window panel conflict
Does anyone else out there use the Marvin Windows & Doors library from Marvin Windows?
We use it pretty extensively. I like the objects and my firm uses Marvin a lot, so it's nice. However, I came across an interesting issue. If the Marvin Windows & Doors library is loaded into a file, no window in the file will recognize a custom window panel. Custom door panels work just fine. If you remove the libraries the custom window panels start working great (e.i. work). I showed the user who found the problem a way to get what she wanted with the custom H-V grid, but it's only a matter of time before there's a bigger conflict which actually needs a custom panel in a window.
Any thoughts?
thanks.
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
1 REPLY 1
This came up again and I figure it out. There are duplicate macro files in the marvin libraries. So I just deleted them (Custom Object Macros 10) and the custom panels work fine.
Jared Banks, AIA
