2004-01-15
03:01 PM
2023-05-26
12:25 PM
Rubia Torres
2004-01-15 07:26 PM
2004-01-15 07:59 PM
David wrote:David, do you know why this might be? If you are transferring properties, it should be obvious that one would wish to transfer the ID# as well...or am I missing something...I can't think of any reason why you would not want to transfer the ID# as well...
FYI - The Eyedropper actually ignores the ID# when transferring properties to pre-placed elements.
2004-01-16 11:51 PM
2004-01-17 12:58 AM
2004-01-17 03:36 PM
Miquel wrote:It would be better to have a non-modal settings dialog/palette (like SEOs and the camera tool) so you could select the specific attributes to be transfered.
A good way would be to have a dialog (like when you are transferring properties in PlotMaker) to allow different choices to transfer with the eyedropper
