Medicine Cabinet 11
Has anyone else come across the situation where if you change the medicine cabinet 11 object is set to 1'-9" wide, it creates an error. Slightly larger or smaller - no problem. I am using US AC11 build 1114 on XP.
Error Message:
Polygon is degenerated.
at line 92 in the 3D script of file Medicine Cabinet 11.gsm
at line 101 in the 3D script of file Medicine Cabinet 11.gsm
0 REPLIES 0
