Metal Deck?
What do you use for metal roof deck? Everything i see runs the wrong direction.
4 REPLIES 4
not quite sure what u mean?? do u mean the hatching runs the wrong way?? if so u can rotate its direction. if not, a bit more detail to your question will help
Have you tried the Roof Accessory? (Select roof, go to Design> Design Extras> Accessories> Roof Accessories )
Yes i don't see an option to make the deck run horizontally instead of vertically.
Chazz
If you are using a flat roof, you just chanhge the orentation of the springline. However, if the roof is (like a roof) sloped then you just sit there seething at the makers of this insane tool that makes corrugated roofs and standing seam roofs just fine but makes roof decks EXACTLY WRONG.
ArchiCAD is an architecture tool. It's supposed to get the architecture part right. Right?
/rant
Nattering nabob of negativism
