Metal Decking
Happy Father's Day
Does anybody knows if there exist a library part, even if commercially available, to depict corrugated metal; the type used for concrete deck slabs.
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
6 REPLIES 6
You can find it in lib. (object/steel construction).
SeaGeoff
Ace
I made a part a while back. You can find it here. HTH.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Thanks Geoff. It was exaclty what I was looking for.
SeaGeoff
Ace
My pleasure. I should upload this to the repository. BTW I could not locate anything in the library, 77. Can you be more specific. Thanks.
Regards,
Geoff Briggs
Geoff-
Thanks for the metal pan deck library part!
If you add a parameter for the roof slope (say 'Z' and set it to angular 0.0000) and then add "ROTY Z" to the beginning of your 3D script the deck can now be sloped to follow the joist slope. I tried it and it works great.
Tom
Djordje
As already stated, there ARE the corrugated sheet objects in the standard library ...
Great work, Geoff
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
