laszlonagy wrote:
You mean you used AC14 FULL and now use AC15 EDU?
I don't know if the migration would work in that case.
AC14 FULL to AC15 FULL or AC14 EDU to AC15 EDU, that should work.
Thanks for the reply!
I've used the EDU version for both AC 14 and 15; (the licenses expire after one year, so we have to upgrade).
Installing the 14 migration libraries in AC 15 does not seem to not replace the "missing objects" in the file, which was original created using 14. I've been using the latest version of Mac OSX ... (My next plan is to try using my PC to open the file, and maybe it will make some difference, since I have managed to do this once before successfully, but am having no luck currently.)
I am trying to attach 2 screenshots before and after loading the libraries. Perhaps I am doing something wrong? I've refreshed the element list from here. I also previously tried embedding the folder contents into the file.
Thanks again for your help.
Brittney
