J S Shelton
Minimal space in plumbing fixtures - turning plan view on?
I am trying to find the on-off parameter for the plan display of minimal space for the plumbing objects. I'm on V14 EDU at a tertiary institute.
ArchiCAD SE on Windows 7 Am I the last person on earth to get 64 bits? Whee!
3 Replies 3
Check the Model View Options Dialog to see if there are settings for plumbing or MEP elements somewhere.
David Maudlin
J S Shelton:
Look under Model View Options > Options for GDL Objects (ArchiCAD 14) > Show Minimum Space of Furnishings and Doors.
If you are using 14, then your signature needs an update.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Maybe the plumbing fixtures have separate settings.
I was supposing he is using the MEP Modeler and those may have a separate panel in the MVO Dialog.
