Missing objects
Dontknow
When I go to the 'Library Manager' I've got a missing object.
It's a 'Story Marker 17+ (4)' from an unknown library.
Anyone any idea what this could be?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
The missing object is the storey level marker selected in the settings of sections / elevations, simply change the storey marker to the equivalent marker in AC18 and this will no longer report as missing
Scott
Dontknow
Oke, thnx.
Found them it in my 'Elevation settings'.
ArchiCAD 25.
