Missing surfaces
Llian
This warning of missing library parts is annoying. I am not sure how to fix it ie how do I get these missing surfaces back into the library.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 REPLY 1
Erwin Edel
Looks like you've unloaded a library that had these surfaces, or perhaps migrated an older project to a new version and these textures are no longer in the library. You should be able to select the missing textures in the loading report and get info to see which surface in the project has them missing. You could remove the textures there or replace them with something else if you did migrate to a newer version.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
