rgarand
Modifing a Zone Stamp
Hello all,
We are pulling out our hair here trying to fumble through customizing our Zone Stamp. We like the Zone Identifier 2 and have been able to manipulate the variables we want to see in our Room Finish Schedules/Info Box. Our problem is that we do not want the Frame box to size according to the Zone Name. We would like it to size according to the width of the Room Number/Room Area etc.
Any help would be appreciated.
Since we do not know much about GDL programming, does anyone know a good resource for GDL in ArchiCAD 9, or is the GDL Cookbook ok to look at for Version 9 GDL?
TIA
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
11 Replies 11
these are the voices
surface
volume
windows surface
illuminating relationship
doors surface
walls up inside surface
wall up clean surfaces
summation windows width
summation doors width
zone perimeter
walls perimeter
hole perimeter
zone height
intelligent height (middle height under roofs)
store height
number angles zone
number angles concave zone
clean ceiling surface
clean floor surface
clean ceiling surface (slab)
clean floor surface (slab)
tilted ceiling surface (roof)
tilted floor surface (roof)
ceiling surface (clean beams )
floor surface (clean beams )
ceiling surface (niches )
side surface (niche )
frontal surface (niche)
a) reduction surface (wall )
b) reduction surface (column)
c) reduction surface (fill)
d) reduction surface (under roof )
reduction summation (a+b+c+d)
remaining surface
reduction's value
total reduced remaining surface
personal text 1
personal text 2
personal text 3
empty
You can insert max eleven of these names
with personal sequence
Chazz
rgarand wrote:
Hello all,
I'm not sure I understand your issue completely (and I know you've solved it already) but t seems that the "Room Identifier_NCS"would do the trick right out of the box. It's included with AC 9 and can be accessed by changing the Stamp in Options / Attribute settings / Zone Categories.
My issue, however, is not solved by any of the identifiers and that is: I want the room # to be the ID of the zone. Isn't this what everyone wants? That way, ID manager can assign your room #'s automatically. Has anyone made a zone Identifier that works this (maybe superior) way? Any help appreciated.
Nattering nabob of negativism
