Modifying windows,skylights and doors
I am using archicad 14 edu for a school project/presentation. I wanted to change doors/skylights to accurately match my survey information.
Project background:
Survey a cell block at Eastern State Penitentiary. My detail drawings include skylights and cell doors
I want to modify skylights and doors in archicad to match my sketches. Does someone know where in archicad I can find resource help on modifying library items such as doors/windows/skylights? I tried drawing them using archicad line command like in Autocad but they don’t show in layout-book.
To summarize I want to modify doors, windows, and skylights to match my survey sketches.
Thank you,
Glenn.
To better understand what your after, do a screen capture of 3d view and annotate with lines/text explaining specifically what it is your trying to modify/accomplice.
David Maudlin
Glenn wrote:
I want to modify skylights and doors in archicad to match my sketches. Does someone know where in archicad I can find resource help on modifying library items such as doors/windows/skylights?.
To create a custom door panel, see in the Help files: Virtual Building > Parametric Objects > Custom Components. You could also put an empty opening the the wall/ceiling then use the other ArchiCAD tools to create the custom door/window/skylight elements without creating the actual custom library part.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
