Modular Moveable Wall Systems
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-05-28
11:51 PM
2023-05-24
12:01 PM
Rubia Torres
Should I use Window builder add on? Objects? Parametric Objects (way beyond my abilities) Complex walls? or is there an add on for building demountable walls?
Ideally there would be an add on made by the partition supplier...I can only dream.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-05-30 12:21 PM
B wrote:Without seeing what type of demountable partition system you are using, my Suggestion is use the Complex Profiles tool combined with Niche window object . Very powerful combination to make complex walls.
I need ideas. I am trying to model a modular demountable partition system. We need to have the system work in rendering, interior elevation and in section.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-05-30 05:12 PM
I should also try using the niche window. It might give me some more options. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-05-31 02:35 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-05-31 04:07 AM
It might be possible to do something with a combination of profiles and simple parametric parts, but we would have to see what you are after to know what to suggest.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-02 04:58 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-06-03 06:11 AM
Use the storefronts to create the fixed panels, both glass and red.
Place a sliding door that sits outside of the wall. Set it's panel to match the system.
You will have to make a custom library part for the door handles as no AC ones match what you show.
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-25 10:06 PM
Trying to make something similar
Erika wrote:Is possible to insert a storefront in a wall without any door?
Erika wrote:Is possible to place two doors at the same time in a wall, sliding door and storefront door?
Sorry for asking, I am trying to understand your suggestion, Erika.
