ā2008-05-28
11:51 PM
ā2023-05-24
12:01 PM
Rubia Torres
ā2008-05-30 12:21 PM
B wrote:Without seeing what type of demountable partition system you are using, my Suggestion is use the Complex Profiles tool combined with Niche window object . Very powerful combination to make complex walls.
I need ideas. I am trying to model a modular demountable partition system. We need to have the system work in rendering, interior elevation and in section.
Should I use Window builder add on? Objects? Parametric Objects (way beyond my abilities) Complex walls? or is there an add on for building demountable walls?
Ideally there would be an add on made by the partition supplier...I can only dream.
ā2008-05-30 05:12 PM
ā2008-05-31 02:35 AM
ā2008-05-31 04:07 AM
ā2008-06-02 04:58 PM
ā2008-06-03 06:11 AM
ā2011-04-25 10:06 PM
Erika wrote:Is possible to insert a storefront in a wall without any door?
Use the storefronts to create the fixed panels, both glass and red.
Erika wrote:Is possible to place two doors at the same time in a wall, sliding door and storefront door?
Place a sliding door that sits outside of the wall. Set it's panel to match the system.
