JGoode
Move Text but also give starting position
I have some text that needs to start in the middle of a line that changes length which is of course very straight forward. However I need to be able to move the text using hotspots.
So my question is how do I start my hotspots at "line/2" but also have the ability to move it without it being locked down?
Thanks
ArchiCAD 27
Windows 10
1 Reply 1
David Maudlin
JGoode:
Use an Add2 command for the initial position. Then before the Text2 command, add 2 movable hotspots (one for x and one for y), then a Add2 command with the movable hotspot parameters. Make the movable hotspots parameters visible in the interface so they can be reset to zero if necessary.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
