ā2014-05-26 12:37 PM
ā2014-05-26 01:23 PM
ā2014-05-26 03:24 PM
JoeyCAD wrote:In the Create Fly-Through dialog box, check the Rebuild Model for Each Frame option.
I'm trying to include moving vehicles on the road moving along the same path and at the same speed, and am having problems! I'm firstly trying to use the cars included in the library that have the option to 'move along path', but no matter what settings within that option I use, they don't move. Can anyone clarify what they should be? (image attached)
ā2014-05-26 11:34 PM
fuzzytnth3 wrote:Grand, thanks. My GDL is pretty amateur, but I'll give it a go! The road's not a 'correct' curve, it's extracted from some Digimap data; so getting the radius right may be complicated... the M40 is a nightmare at the best of times! I was intrigued about the built in aspect of the 'follow path' in the cars included in the library, as I'm hoping they'll do the runt work for me, if I can get them to work!
Might be worth checking out this thread...
archicad-talk.graphisoft.com/viewtopic.php?p=204243#204243
In your case you will need to add some trig to the calculation to follow the radius of the road plus to model the speed of 60mph relative to your frame rate of your animation
ā2014-05-26 11:35 PM
David wrote:Forgot to add I had that checked, it didn't make any difference so I assumed I'd got a value in the settings wrong...JoeyCAD wrote:In the Create Fly-Through dialog box, check the Rebuild Model for Each Frame option.
ā2014-05-27 03:18 PM
ā2014-05-30 12:03 PM
David wrote:I did try a test myself in another file with no luck, so it's almost definitely something I'm doing wrong!
JoeyCAD:
Worked here on a quick test, try posting the Create Fly-Through dialog box and a screen shot of the Cameras Settings and camera path, maybe someone will spot the problem.
ā2014-05-30 12:04 PM
JoeyCAD wrote:David wrote:I did try a test myself in another file with no luck, so it's almost definitely something I'm doing wrong!
JoeyCAD:
Attached should be the path settings, camera settings, fly-through settings and the car objects follow path settings that I've been using with no luck!
Any advice would be great, thanks!
ā2014-05-30 12:05 PM
ā2014-05-30 04:19 PM
