‎2010-01-11 08:36 PM
‎2010-01-11 09:12 PM
‎2010-01-11 11:05 PM
‎2010-01-12 02:08 AM
‎2010-01-12 02:31 PM
Barry wrote:The thing is, I don't really know which library to chose, it wasn't a very organised project...
Open the Library Manager and find the required libraries again.
You shouldn't need to do this if everything is on the same machine.
That makes me think the libraries may have been moved or deleted as well.
‎2010-01-12 03:40 PM
‎2010-01-12 06:34 PM
‎2010-01-12 07:06 PM
Erika wrote:Thank you, Just to make sure, if I create a new folder, I select the Archicad 13 library folder, and does it create a subfolder into that ? If I decided to move a file from say " Documents to " my desktop " would I need to save it as a archive file as it is been moved? I moved a .pln file from " my desktop " to " my documents" and that is why the library parts a re' missing ' but I have relocated them and will probably crate a archive file now so that ALL parts are in the AC 13 library folder?
N,
When you open the archive you are asked if you want to
read the library directly from the file, or create a new file folder of the used parts in the pla. If you are going to be using other library parts such as other parts within the standard archicad library, then you should chose the option to create a library folder.
Then you can load the AC standard library that is on your computer. Unload the folders of AC standard library parts from the pla so you will not get duplicate library parts.
In the end you will have loaded
- your standard AC library
- folder of non AC library parts that you got from the pla.
Hope this is clear enough. (Makes sense when you know it🙂 )
‎2010-01-12 11:25 PM
