MultiLine Text in Script
Is it possible to get a "return" to work so I can have another
line of text below what I've shown in the attached script?
Thanks
lec
8 Replies 8
Two ways I know of:
1. Use the PARAGRAPH statement and associated text functions. I found these to be complicated to get working correctly but once I sorted it out they worked nicely.
2. Parse the text procedurally. This goes something like:
FOR i = 1 TO STRLEN(string_parameter)
    char = SUBSTR(string_parameter, i, 1)
    IF char = " " THEN   ! find space character
        ! do something
    ENDIF
NEXT i
The details of course depend on what you want to do. This is the method I used before the multi-line text functions were introduced. I still use it in simple cases or where I need special control over parsing the text.
EDIT: Three ways...
3. Use two parameters. One for line one and the other for line two.
Rod Jurich
lec1212 wrote:
/.......Is it possible to get a "return" to work so I can have another
If memory serves me well it was ML who suggested to us \n as shown in attached
Works in 99% of cases. Not custom dimensions or label ID
Add for a 3rd line works also. ---\n---\n---
Rod Jurich
Hi Rod
Thanks for simple approach as I'm not a gdl guy.
However so far I've only got the box shown in screen shot.
And I have tried many variations (spaces-no spaces etc) (just for fun) with no success yet.
Thanks for the idea though.
lec
I think this may be because it is 3D text and not 2D as in Rod's example.
Interestingly \t works (tab).
But then that is not forcing a new line.
Yep works fine if you add the text to the 2D view.
Must just be a 3D thing.
Thanks for additional info Barry.
lec
I am having a related problem. I have read in a string from an external source. The string had a return/new line in it. It is showing up in the library part as the square shown above, so I know that it is there. I am looking to Parse the string and seperate it into 2 strings based on the new line. Shouldn't be a problem, however when I search the string for either "\n" or "\new line" it returns 0 (not found). Is there something I am missing or is it just not possible to search for the new line character.
I ended up using a workaround of searching for all alpha-numeric characters and if the character was not one, then just assuming that that is the new line character. Not the best solution, but it will work for now.
