I was wondering if there was a way to reduce the line after the title text.
It seems to be a standard length after all the titles of my placed drawing in the layout book. I would like to make it shorter. I can't find any more options to manipulate it in the title parameters so it must be a GDL thing. If someone knows what to change it would be most helpful.
NCS Drawing Title 2 13
I already have my set to: Link Width to - Title Texts
I spend a lot of time manipulating the length of these lines for each title. I usually have it set to "length parameter" and recently just discovered the option to set it to "title text." I figured "title text" would make it just long enough to fit under the title text as the name suggests, but it seems to go to some arbitrary length regardless of the title length.
It is in the Object Library 13.lcf of the US version, I don't know about other versions.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual ⢠Mac mini M4 Pro OSX15 | 64 gb ram ⢠MacBook Pro M3 Pro | 36 gb ram OSX14
It might not be included in the Library that comes with your version of ArchiCAD (mine is US version). If you post the language/county version of your ArchiCAD (check License Information...) someone else with the same version might be able to confirm.
