NCS Drawing Title 2 13 - Link width to - Title Texts
I was wondering if there was a way to reduce the line after the title text.
It seems to be a standard length after all the titles of my placed drawing in the layout book. I would like to make it shorter. I can't find any more options to manipulate it in the title parameters so it must be a GDL thing. If someone knows what to change it would be most helpful.
I already have my set to: Link Width to - Title Texts
9 REPLIES 9
Erika Epstein
If you set it to Length parameter instead you can define the length of the line.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I spend a lot of time manipulating the length of these lines for each title. I usually have it set to "length parameter" and recently just discovered the option to set it to "title text." I figured "title text" would make it just long enough to fit under the title text as the name suggests, but it seems to go to some arbitrary length regardless of the title length.
What gives??
Not to sound like a complete idiot, but is the NCS Drawing Title 2 13 found in the Archicad native library?
Thanks and sorry for bumping an old topic.
David Maudlin
Rian:
It is in the Object Library 13.lcf of the US version, I don't know about other versions.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David, although I still can't find it if it is in the default library of AC13.
David Maudlin
Rian:
It might not be included in the Library that comes with your version of ArchiCAD (mine is US version). If you post the language/county version of your ArchiCAD (check License Information...) someone else with the same version might be able to confirm.
David
David,
Here is the information. Checked with others, I think it is not available in the International version.
Version: 13.0.0
Build Number: 3000
Language Version: English (International)
Library Build Number: 3000
License Type: Commercial
If anyone knows where I can acquire this title block, it would be much appreciated. Thanks!
Rod Jurich
Rian, attached find USA Marker Symbols with the Marker Macro 13 folder enclosed.
Rod Jurich
Thanks a lot Rod, that was extremely helpful.
