Name_of_plan not adding to parameter
JGoode
Hello,
I'm trying to add the name of my project to a parameter but for some reason it doesn't fill the field?
Here is my script:
rrr=REQUEST("Name_of_plan", "", prj_name, prj_fullname, prj_path)
zx = prj_fullname
parameters zx=zx
I feel like this should just work but doesn't, Any ideas as to how to solve it?
Thanks
ArchiCAD 27
Windows 10
13 REPLIES 13
JGoode wrote:
Hello,
Here is my script:
zx = prj_fullname
parameters zx=zx
Thanks
I don't think you can add it to a parameter value.
But there is no problem with the REQUEST and the returned values - except for prj_name - this doesn't seem to do anything.
But the returned vales for prj_fullname & prj_path work just fine in the master or any other script.
Nader Belal
Mentor
@Ling
The second quote doesn't appear to me ... I wonder why ??
@Ling + @JGoode
It can work, if you create custom autotexts, then all you have to do is to concatenate them.
Lingwisyer
Guru
As in it is blank in the post? Or that you cannot find it in the thread? It is from the GDL forum
JGoode wrote:
What I want to achieve involves cutting up the name of the project to get the first 5 numbers of the project name. I have no use for it to be outputted in 2D / 3D. It’s not necessarily needing to store it as a parameter but I do need to be able to use the string (like a parameter). I don’t know if there is a way of doing so?
Use STRSUB to get just part of the fullname.
You still can't set it as a parameter, but you can use it in a TEXT2 command, or I have used this to create text files for various outputs, so they have the same name as my Archicad file.
