New Object 3DMD Polyline Pathway
Mario Sacco
I made this new object, based on the same macro used for 3DMD Polyline Fence.
http://archicad-talk.graphisoft.com/viewtopic.php?p=232856#232856
A 3d editable poly-line. The texture follow the path.
It's in beta test. I'm still working on many bags and enhancements.
Let me know if you have questions.
I hope it will useful for your works.
The link for the download is here:
https://www.dropbox.com/sh/86y9z3intan2lq3/AACdWNuzn503ZL-jjikiM9q-a?dl=0
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
28 REPLIES 28
Hmooslechner
and the next step for this object could be crossings...
Mario Sacco
As soon as I can I'll publish also the new update with the possibility to do any kind of crossing and branches, using more than one internal solid subtraction; so you'll be able to have a realistic 2d projection.
Mario, this object just keeps getting more and more awesome.
I check the video and am I right in assuming that you use the Gravity function when placing new nodes for the object so when a new pathway node is created it finds the proper surface height of the Mesh it is placed on?
Mario Sacco
Thank you!
I used not the gravity function but the Snap Surface!
Ah, OK, that's right.
Mario Sacco
Laszlo
I have problem to upload the object 3DMD Polyline pathway on BIm COmponents. The problem seem to be on finding the macro. I didn't have problem to upload the object 3DMD Polyline Fence that has the same macro with a different name.
The name of the macro called in the object is the same of the macro. The object have no problem in the archicad file. You can find my objects here.
https://www.dropbox.com/home/3DMD%20Download
This is the message graphisoft reported me:
WOPE 18.0.0 build 2651
Converting GSMs to XMLs
Converting XMLs to GSMs
C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML4952\3DMD Polyline Pathway\3DMD Polyline Pathway M.xml(4982) : error: XML validation failed; element name expected
C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML4952\3DMD Polyline Pathway\3DMD Polyline Pathway.xml(0) : error: Missing called macro or file '3DMD Polyline Pathway M'.
The object is locked due the fact I'll use the same macro to create commercial objects. I saw no support on Developer forum about this kind of topic.
Can you help me?
Didn't you get a feedback email from bimcomponents.com or some information about how to solve this issue or something?
I think only GS HQ knows what these messages mean and how to fix them.
Mario Sacco
I think I solved. I'm waiting the object published. They haven't still send me error message. The error I made was: you must always add space before and after the symbol "<" or ">". Otherwise in the conversion from gdl to xml works fine but from xml to gdl gets the error I described.
It was hard to understand. I used LP_XMLConverter.EXE.
I hope it will be published on monday.
Thank you Laszlo!
Glad you got it sorted.
Mario Sacco
I finally managed to upload the object on bimcomponents.
https://bimcomponents.com/LCF/Details/4984
