No option to change fill type in Door w sidelight?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-04-12
10:31 AM
‎2023-05-24
10:52 AM
Rubia Torres
‎2013-04-12
10:31 AM
And it also doesn't appear in the parameters tab
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-04-17 07:19 PM
‎2013-04-17
07:19 PM
In order to use the attributes of the 2d parameters menu, you have to UNcheck the two options in floorplan and section fields, then in 2d parameters you can have more options to change.
I hope that is what you meant..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-04-18 11:56 AM
‎2013-04-18
11:56 AM
No, this is not what I meant.
I meant that in the options, no matter what, the pens and fills for sidelight are always dimmed
also in the parameters tab there are no fills and pens for the sidelight
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-04-22 03:42 PM
‎2013-04-22
03:42 PM
Achille wrote:Hi Achille,
try to set a parapet height on the next tab, from that point all settings should be available. By default it is greyed out as it uses the same pens as the main door.
I hope this helps,
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
GRAPHISOFT
