Object Error Message: "Can't find Marcro....
rob2218
see attached.
object is looking for something but not sure how to resolve it.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
11 REPLIES 11
Objects often 'CALL' other objects or macros to save re-writing the same scripts in different objects.
There is not a lot you can do except to find this missing macro and make sure it is a part of your loaded library.
If the object was downloaded from a 3rd party you may be able to go back to that source and re-download to get all the required library parts.
If it is a GS object (I don't think it is - DMS is probably somebodies initials) then I don't know why the called macro would be missing.
Rob / Barry:
DMS re the initials of Dvid Sanders (coincidentally are also my own initials) David's library is great.
Rob:
I guess you can contact David thru this forum and most likely he will be able to tell you what you are missing there.
Regards,
Diego
I apologize for the multiple posting. I do not know what happened.
All fixed.
Rob,
The "RA_Rounded" file is marco located in the Accessories Library.
Download and install the Accessories Goodie for your AC version. The Accessories LIbrary will be added to your ARCHICAD folder.
Add the Accessories Library to your project.
rob2218
Is The "Accessories" folder a folder that is already IN my ARCHICAD program or is it something I have to download and then install?
laszlonagy wrote:
Rob,
i>u
Edgewater, FL!
SOFTWARE VERSION:
Yes, the Accessories Library will be added to your ARCHICAD folder during the installation of the Accessories Goodie.
rob2218
great..........states on the "goodies" and "accessories" page that the accessories and goodies ONLY will work for build 3006. We are at build 6000 with AC18.
so.....I think that is why I never installed it to begin with. Saw that statement and thought it wont work.
http://www.graphisoft.com/downloads/goodies/AC18/USA.html
i>u
Edgewater, FL!
SOFTWARE VERSION:
Just do it, it will work with all later builds as well. I just tried it.
