Thanks for that Matthew, Seems to be exactly the same as the Object Label 11.
Thanks for the tip to get it to snap to the centre of the beam. But the main problem with all the standard Labels is you can't specify arrow line lengths initially. You have to edit them all twice to get them where you want.
I searched "Labels" before I posted, and in 2004 you and others were complaining about this and other issues about Labels then. 4+ years later and still nothing has been done. Perhaps the Automatic Annotation Tool will change this.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
