Object Needed - Or advise on where to start building
Dear all
There is one object that I would find very useful in all things from furniture to buildings - it's like this
Its a basic block, where you can specify height, length and width, so it could look like a wall or a slab. Pretty straightforward stuff...
BUT...All twelve edges (arrises) can be set to be either rounded or chamfered to a user-defined radius.
I'm guessing that this would be a really simple object to code, but would lend realism to a LOT of internal and close-up views, where super sharp edges just don't look like the real world.
If anyone has such a library part, then I would be incredibly grateful to borrow it. Otherwise I'll buy the cookbook and have one to share - in about 6 months!
Djordje
You obviously did not try ArchiForma.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Kevin wrote:
Dear all
This is an easy job with HPRISM_, would be a good exercise to get to a short time after you start with GDL......
>>davidnc
