2023-01-05 02:48 PM - last edited on 2024-03-07 11:06 PM by Karl Ottenstein
Does anyone know why this might be happening?
(the object was created with PARAM-O and has another object inside of it.)
2023-01-05 05:57 PM
When you copy and paste you automatically have both objects because one is called from the main object (i.e. it is part of the main object).
With the Library Manager you will need to import both objects because in the library they are separate objects.
