Objects materials (parameters) problem
Hi.
I'm ussing Archicad 14 (EDU) with all updates.
And i still having (i really don't know why, just happend) an issue with a lot of objects from the library... i can't change they materials, also appears with only one material, even if i change the object parameter.
Somebody can help me.?
4 REPLIES 4
In the object settings ...
I'm experience the same problem and I suspect the graphic-card which, in my case, is GeForce GTX 550 Ti. I recently upgraded 4 computer's and they all have the same problem (and the same graphic-card type).
It's only in OpenGL mode that this occurs. Renderings are fine and Internal mode works fine.
I'll run some test and maybe I'll be able to post a solution soon.
Thank you!
It works
