Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Objects missing in Archicad 12
I just got my upgrade copy of Archicad. I am missing storefront doors and windows in the default library. Shouldn't they be there?
Justin
4 REPLIES 4
Dwight
Suss out new curtain wall tool.
Dwight Atkinson
Come again!
Justin
Gerald Hoffman
'Suss' - to check out. I believe storefront doors and windows have been replaced by the new curtain wall tool.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-5030 USA
2019 MacBook Pro (64GB w/ AMD Radeon Pro 5600M GPU)
__archiben
for better or worse, those objects have been replaced by the new curtain wall tool.
the archicad 11 migration library is included in the installation by default: make sure you load that library with any existing 11 project . . . or if you want to use those objects in 12...
./Applications/Graphisoft/ArchiCAD 12/ArchiCAD 11 Migration Library
~/archiben
b e n f r o s t
